rapids27 Posted April 5, 2014 Share Posted April 5, 2014 Hi Guys - could do with some help. Today I purchased a Line 6Pod500x and I thought I would update all the bits. I have downloaded and installed Line 6 Monkey and updated the drivers. However, I cannot update the Flash Memory (from 1.0 to 1.2) which I would like to do. I also have noticed that the factory preset lists are screwed up (not sure if I did that playing around with Edit and Monkey) or not, but the Best of HD set list is half missing - would like to get it back if possible. I have tried holding down the left arrow whilst powering on - no luck. I keep getting the following message, when attempting to update the Flash Memory: Code 8007211 Firmware update timed out waiting for response from the device. The pod is connected, powered on, USB connected and can be seen by Monkey. I have tried 3 different USB ports and even tried updating from the file I downloaded. One thing I did notice was that my Drivers are version 4.2.7.1 whereas Monkey has the newest listed as 4.2.6.9. Could this be part of the problem ? Should I try udowngrading to the 4.2.6.9 drivers and try flash update again. Or Is there something else I should do ? Thanks for any help :) Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 5, 2014 Share Posted April 5, 2014 Are you using the newest version of Monkey? http://line6.com/software/ Did you try another USB cable? Also try temporarily disabling any anti-virus/firewall. Quote Link to comment Share on other sites More sharing options...
rapids27 Posted April 5, 2014 Author Share Posted April 5, 2014 Hi Thanks for the suggestion to try another usb cable. Unfortunately I dont have another cable like the one they supply. I have also tried disabling my security software as well but same result. Also noticed last night after I posted that the unit and the Edit software wont talk either - I get another error message (different to flash update one ). Shouldnt be this hard. Anyway after trying for nearly 12 hours yesterday to make things work - I have decided to take the unit back to the store later today and see if I can get a refund. Quote Link to comment Share on other sites More sharing options...
rapids27 Posted April 6, 2014 Author Share Posted April 6, 2014 Problem solved. Returned unit for a full refund. Store confirmed that unit I had, had software issues. Quote Link to comment Share on other sites More sharing options...
