New Bug with Firmware 3.71?
DeArmin
Problem with new firmware 3.71
Hello everyone, today I installed the new firmware 3.71 in my Stomp xl. First I made a backup and then carried out the update. Then a reset and the backup restore were carried out. So far everything worked. Afterwards I tested my presets and found that all my delays no longer worked. I use delays in mono, especially the Adriatic Delay. I had to increase the time setting from 1/4 to 1/16 for all delays. With the previous settings (time 1/4) the delays were terribly scratchy/ like clipping or distortion. I have nothing change after restore my backup. Do any of you have the same problem?
Update: I have found out, when the setting for the tempo is in ms, e.g. 330 ms, it works similar as 1/16.
