jeewilly Posted May 10, 2024 Share Posted May 10, 2024 I have a HOTONE Ampero Control Sending MIDI to a Timefactor and then THRU to my HX One. Currently PC messages and some CC messages are working fine, but I cannot get it to respond to CC64-127 (tap tempo) or CC93-127 (enter tap tempo). I have tried everything I can think of... MIDI Clock RX off, on, auto. (When set to on or auto, MIDI clock is working fine -- Clock coming from Timefactor) As I said above, other CC messages are working fine, but can't get anything related to tap to work properly. Wondering if this might be a bug. I am on software 3.71.0 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 10, 2024 Share Posted May 10, 2024 There are other reports that seem to support your findings. In the current manual the reference to CC64 was taken out. It says Tap Tempo is on CC93. I don't have a HX One at hand to verify whether CC93 works. Contact support! 1 Quote Link to comment Share on other sites More sharing options...
jeewilly Posted May 10, 2024 Author Share Posted May 10, 2024 On 5/10/2024 at 10:27 AM, Schmalle said: There are other reports that seem to support your findings. In the current manual the reference to CC64 was taken out. It says Tap Tempo is on CC93. I don't have a HX One at hand to verify whether CC93 works. Contact support! Thank you for the response! I just tested an can confirm CC93 works for tap tempo. In the manual (old version apparently) I was looking at CC93 was labeled as 'enters tap tempo', and it still said CC64 was used for tap tempo. So when I tested CC93 orginally, I just did a single button press. I've been racking my brain on what I was doing wrong, so thanks again! 1 Quote Link to comment Share on other sites More sharing options...
