Revucky Posted June 30 Share Posted June 30 First off - yes, this topic was mentioned earlier, yes - I did everything others recommended, yet the problem still remaines. EXP1 can switch between VOL and WAH, but moving the pedal doesn't do anything. I have the latest version (2.01), I tried to clear it completly and import the backup - the problem still remains. If anyone had similar or exactly the same problem please respond, I'm losing my mind and have a gig in 2 weeks. Quote Link to comment Share on other sites More sharing options...
theElevators Posted July 2 Share Posted July 2 make sure that you have assigned the proper values to EXP 1. It depends on your preset -- the expression 1 or 2 pedal can only do stuff if that particular parameter is assigned to it. I use the Expression pedal 1 to control the Delay block feedback for example. Go and double check in Pod Go edit that: 1. you right click on the wah parameter, or any other parameter of any block you need it to control. 2. it is assigned to "EXP 1" If it's not assigned to anything, then moving the pedal won't do anything. By default, when you drag in your wah pedal, it has assignments created for you, so maybe clear the block and re-add a wah pedal. If it doesn't work, then the expression pedal died, I'm afraid. Quote Link to comment Share on other sites More sharing options...
