Lower volume with stereo inputs?
rb3wreath
I’ve just built a flat pedalboard that I can use with both my acoustic guitar (fitted with a K&K Trinity Pro: has both a 9V condenser mic and transducer pickups) and my electric guitars. I opted to use the HX Stomp because I can route the mic from my acoustic guitar to the R input of the HX Stomp and the transducer pickups to the L input. Then I can process them separately with different EQs/etc and then I’m blending them back together send them to a PA from the L Output.
I just discovered when plugging in my electric guitars that the electric guitar volume and tone was significantly diminished. It took me a while to figure out, but it seems to be happening because the 1/4” plug for the mic input is plugged in to the R Input on the back of the HX Stomp. When I’m using it with my electric guitar, I make sure to turn off my 9V phantom power (the small silver box at the top right of my picture).
If I pull the R Input jack out from the HX Stomp when I’m playing electric guitars through the rig then the volume comes back to normal and isn’t decreased. I guess this is still an “okay” solution for me. It just means that I have to do two different things when switching between electric and acoustic (deal with the R Input being in or out and turning on/off the 9V phantom power).
Does anyone know if it’s possible to not have to unplug the R Input and keep to volume at the normal level when switching to play electrics through this setup?
Use a Stereo Return Block with the K&K connected to the RETURNS and Electric connected to the L/Mono Input.
Put the Return Block in a parallel path and use the PANS to keep the signals separated.
Example preset attached. Note the Split Block setting.
rb3wreath.hlx
Thanks for the suggestion and the sample preset. That’s an interesting idea. I was using the split block with the L & R inputs and that was working fine enough … for my acoustic guitar. I’ll give the RETURN block idea a shot tomorrow morning. I’m assuming I can use the RETURN just for the K&K’s 9V mic and the L/Mono Input for the K&K’s standard transducer pickups? If so, that’ll be ideal.
Should work fine.
Thank you @rd2rk! It works great. Whew! This is gonna be so much better than what I was doing before.
I've got the 9V mic output going into the R/Return. Now all I've gotta do to switch to my elec guitar is just turn off the 9V phantom power (and switch to a diff preset). I need to spend a little more time dialing in the EQ, but this new preset gives me a 4dB boost and quick reverb (or whatever other effect I'd need). I doubt I'll ever use the reverb in a gig (bluegrass acoustic with a band), but good to know I've got the option.
Trinity Pro.hlx
