HX Effects Tuner
mvenet
Just wondering if anyone uses separate tuner with HX Effects because HX Effects tuner is not very dependable.
Not saying it's inaccurate. However, and this is especially true in live situation, the HX Effects tuner display (I have tried the course, fine and strobe settings and do prefer strobe) will bounce all over the place with notes displayed  don't even seem correct. IE I will be getting close to a note (as confirmed with headstock tuner and HX display is bouncing across 3 or 4 different notes)
This has happened to me on two separate HX Effects units. It is a show stopper for me.
Interestingly enough, the tuner on the HX stomp XL seems to be rock solid and bullet proof.
HX Effects firmware is the latest 3.7.1.
Thanks,
I've been using one (mostly) cheap clip-on tuner or another on stage for as long as I can remember. Never fails, easily visible on a dark stage, no toggling in and out of tuner mode or engaging a separate pedal. And unless you're jumping around like EVH in his prime it ain't going anywhere. Just roll off the volume knob, tune, done. Through more years than I can count, I can recall exactly one instance where it fell off the headstock. And the cheapo Snark tuners you can get for about 12 bucks are just as good as the fancier expensive ones. I probably wouldn't use one to set intonation, but for tuning up between songs they work just fine.
The tuner in the Helix family of products is absolutely fine.  I have used it live and in studio: on both Pod Go and Helix.  It's great.  But... it depends what mode you run the tuner in.  The default "fine" is really really frustrating.
The main issue is that the "fine" mode is way too fidgety.  The meter keeps jumping all around and you can't seem to find the center of pitch.  Instead, simply use the "coarse" mode.  It ignores the subtle little changes to the pitch, so you can tune faster without being distracted if you are 1/2 cent off.
If I were to buy an external tuner, I would definitely go with Polytune, so convenient to strum all strings at once and fix what is off.
  • 2 weeks later...
I understand your frustration with the HX Effects tuner, especially in live situations where reliability is crucial. It sounds like the tuner display can be erratic and inaccurate compared to other tuners. Using a separate tuner could definitely help in such cases, ensuring you get precise tuning without the display issues you’ve experienced. It’s interesting to note that the HX Stomp XL’s tuner seems to perform well, so perhaps it’s a specific issue with the HX Effects model. If you haven't already, consider reaching out to Line 6 support for advice or potential firmware fixes. In the meantime, a dedicated tuner could be a worthwhile investment for more dependable performance during your gigs. I hope my answer solves your issue, if you want to know more let me know, I am always ready to help you. If you need help from an online essay writer then you can simply visit https://domypaper.com/ here. Because DoMyPaper offers custom paper writing services, matching students with experts who deliver high-quality, original work. The platform guarantees on-time delivery and provides free revisions to ensure that all academic requirements are met, with customer support available at all times.
Thanks for the info, I will keep it in mind.
I have my hx effects tuner in coarse mode. However, I use a separate Boss TU-3 on my board as a tuner. I don't like the included tuner and this topic has been discused in other threads. Try different tunner modes and try by yourself. But yeah, it isn't at the same level as a dedicated tuner imho.
