kroa38 Posted October 23, 2024 Share Posted October 23, 2024 # Running PODHD Pro X under linux Because we love linux ! Tested on : Ubuntu 22-04 (jammy) ## 1) Get the righ ID of the PODHD PRO X: run the command : ``` > sudo dmesg | grep 'idVendor=0e41' [ 3239.784010] usb 3-1.3.1: New USB device found, idVendor=0e41, idProduct=415a, bcdDevice= 0.00 ``` 0x0e41 = Line 6 Manufacturer ID __0x415a__ = __PODHD Pro X ID__ ## 2) Linux kernel source Get your current kernel version: ``` > uname -r 6.8.0-47-generic ``` Download the most closest version of your kernel: For me is 6.8.0 and extract under __/usr/src/__ ``` > wget https://mirrors.edge.kernel.org/pub/linux/kernel/v6.x/linux-6.6.8.tar.gz > tar -xvf linux-6.6.8.tar.gz > mv linx-6.6.8/ /usr/src/. ``` ## 3) Make Module Prepare Remove root permission ``` > cd /usr/src/ > chown -R $(whoami):$(whoami) linux_6.8.0/ ``` Copy your current kernel config inside the source ``` > cd /usr/src/linux_6.8.0 > cp /boot/config-$(uname -r) .config ``` make module_prepare ``` > cd /usr/src/linux_6.8.0 > cp /boot/config-$(uname -r) .config > make oldconfig > make modules_prepare ``` ## 4) Modify PODHD. C file For working you have to simply modify the value of LINE6_PODHDDESKTOP inside the file : > linux-6.8.0/sound/usb/line6/podhd.c > replace __0x4156__ by __0x415a__ ``` /* table of devices that work with this driver */ static const struct usb_device_id podhd_id_table[] = { /* TODO: no need to alloc data interfaces when only audio is used */ { LINE6_DEVICE(0x5057), .driver_info = LINE6_PODHD300 }, { LINE6_DEVICE(0x5058), .driver_info = LINE6_PODHD400 }, { LINE6_IF_NUM(0x414D, 0), .driver_info = LINE6_PODHD500 }, { LINE6_IF_NUM(0x414A, 0), .driver_info = LINE6_PODX3 }, { LINE6_IF_NUM(0x414B, 0), .driver_info = LINE6_PODX3LIVE }, { LINE6_IF_NUM(0x4159, 0), .driver_info = LINE6_PODHD500X }, { LINE6_IF_NUM(0x415a, 0), .driver_info = LINE6_PODHDDESKTOP }, {} }; ``` ## 5) Rebuild module ``` > cd linux-6.8.0/sound/usb/line6 > make -C /lib/modules/$(uname -r)/build M=$(pwd) modules ``` if all is ok you have successfully build the modules for the PODHD Pro X. ``` > ll *.ko -rw-r--r-- 1 root root 1567408 Oct 23 15:56 snd-usb-line6.ko -rw-r--r-- 1 root root 418600 Oct 23 16:22 snd-usb-podhd.ko -rw-r--r-- 1 root root 417152 Oct 23 15:56 snd-usb-pod.ko -rw-r--r-- 1 root root 438232 Oct 23 15:56 snd-usb-toneport.ko -rw-r--r-- 1 root root 384128 Oct 23 15:56 snd-usb-variax.ko ``` ## 6) unload old module . verify if you have line modules loaded ``` > sudo lsmod | grep snd_usb snd_usb_podhd 16384 0 snd_usb_line6 49152 3 snd_usb_podhd snd_usb_audio 499712 5 snd_usbmidi_lib 53248 1 snd_usb_audio snd_hwdep 20480 3 snd_usb_audio,snd_hda_codec,snd_usb_line6 snd_ump 45056 1 snd_usb_audio snd_rawmidi 57344 4 snd_seq_midi,snd_usbmidi_lib,snd_usb_line6,snd_ump mc 81920 1 snd_usb_audio ``` For me __snd_usb_pod_hd__ and __snd_usb_line6__ must be unloaded ``` > sudo rmmod snd_usb_podhd > sudo rmmod snd_usb_line6 ``` ## 7) Insert new module. Insert first line6 and after podhd ``` > sudo insmod ./snd-usb-line6.ko > sudo insmod ./snd-usb-podhd.ko ``` ## 8) Big thanks to : Markus Grabner <grabner@icg.tugraz.at> who is at the origin of this driver. README.md podhd.c Quote Link to comment Share on other sites More sharing options...
