Pod Go Wireless lost power during update 2.0, now doesn't work.
dowielogan
I was updating my Pod Go Wireless through Line 6 Central on my MacBook from 1.30 to 2.0, and about twenty minutes into the update I bumped the power bar the pod go was plugged into. Oops.
now whenever I turn it on it shows the intro screen with the red outline of the bean pod, saying Line 6 Pod Go wireless, how to videos at..., Firmware 1.30.0
I tried restarting Line 6 Central, but even after that it won't recognize the pod even though I've checked all the connections. I've also flipped off and on the power switch multiple times. I tried holding Page > while powering on, but then it just stays on a blank white screen.
Any help and suggestions appreciated. Thanks
Sorry, I didn't see this sooner.
Download the latest versions of Line 6 Updater, POD Go Edit, and any version of the POD Go firmware - NOT the latest version.
Start your POD Go whilst holding down the 'Page Right' button. Don't worry about the grey screen.
Make sure your computer is not running ANY background music streaming crap like Spotify. Make sure your USB cable is in good nick.
Plug the POD Go to your computer.
Start Line 6 Updater in Offline Mode'.
Select POD Go, select 'Update from file' and install the firmware that you downloaded.
When that installs successfully, close the updater, Switch off the POD Go and do the 'Factory reset' startup procedure.
Plug the POD Go in, start up POD Go Edit.
FOLLOW THE INSTRUCTIONS.
The update will take about half an hour.
