gianu Posted May 30, 2013 Share Posted May 30, 2013 Hi! I have a problem with the analogs outs of my UX2. After connecting the output to my Edifier R2600 I can only hear noises. I can see the VU meters moving with every sound of my computer, but I cannot hear those sounds I only hear noises. I tested that the input of the edifier worked (connect the output audio of my computer directly to the Edifier). I tested that the cable works. I tested the analogs output individualy connecting a headphone, and it works! But when I connect the ux2 to my edifier using the same cable, I can only hear noises. Given that the cable is a RCA, I used two conversor from RCA to Plug to plug the cable to the UX2, the conversors are brand new (bought on a good audio store), could it be the problem? Or is something else that I'm missing? Thanks for your help. :) Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted May 30, 2013 Share Posted May 30, 2013 Make sure you have RCA - MONO 1/4" plug adapters. They should have just 2 conductors on the 1/4" plug. Make sure you have them plugged into the audio outputs of the UX2, as well! :) Quote Link to comment Share on other sites More sharing options...
gianu Posted May 31, 2013 Author Share Posted May 31, 2013 Thanks fflbrgst for the answer! Yes I have two RCA - Mono 1/4'' plug adapters (image: https://dl.dropboxusercontent.com/u/187032/plug.jpg) and they are both plugged into the audio outputs :) (https://dl.dropboxusercontent.com/u/187032/conector.jpg). Quote Link to comment Share on other sites More sharing options...
gianu Posted June 1, 2013 Author Share Posted June 1, 2013 Thanks fflbrgst for the answer! Yes I have two RCA - Mono 1/4'' plug adapters (image: https://dl.dropboxusercontent.com/u/187032/plug.jpg) and they are both plugged into the audio outputs :) (https://dl.dropboxusercontent.com/u/187032/conector.jpg). Another thing that i found is that if the RCA cable are disconnected and I'm playing my guitar I can see the Vu Meter moving (but when I connect the RCA -with the adapter-) to the analog outs, the VU Meters stop moving. Quote Link to comment Share on other sites More sharing options...
gianu Posted June 1, 2013 Author Share Posted June 1, 2013 one more test that I made. If I choose the UX2 as my sound output device (in OSX Preference) when I press the volume up & down I can see the VU Meter moving, so the sound is going to the UX2, but I cannot hear anything from the Edifiers, just a "noise" (static noise I guess). If I move the output volume pot in the UX2 this "noise" is louder, so something seems to be sending. I'm clueless about this. Any hint? Thanks! Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 3, 2013 Share Posted June 3, 2013 Definitely sounds like a connection issue. I currently cannot view your photos (dropbox blocked at my current location) so not sure what your adapters look like. Can you hunt down a set of cable like these? http://www.zzounds.com/item--HOSCPR20 Quote Link to comment Share on other sites More sharing options...
gianu Posted June 4, 2013 Author Share Posted June 4, 2013 Well, I bought some of the cable that Triryche suggested and fixed the problem. Seems to be a problem with the adapters then. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 4, 2013 Share Posted June 4, 2013 Cool!! Glad you got it sorted out. btw, dig the your new avatar!! Quote Link to comment Share on other sites More sharing options...
