jouse Posted April 20, 2014 Share Posted April 20, 2014 hello,i have a probleme with my hd 300,the sound with headphones is very bad noisy is there something to do ? thank you exuse m y english i am french Quote Link to comment Share on other sites More sharing options...
alienux Posted April 20, 2014 Share Posted April 20, 2014 Are you using headphones with a 1/4" connector, or are you using an adapter to go from 1/4" to an 1/8" plug on your headphones? If you have an adapter, it could be causing that. I have some 1/4" to 1/8" adapters that have a little play in them and if I use one, it sometimes causes noise. Quote Link to comment Share on other sites More sharing options...
jouse Posted April 20, 2014 Author Share Posted April 20, 2014 Thank you ,the probleme is with distortion sounds,if i use full version sounds awfull ,i switch to preamp and super sound Quote Link to comment Share on other sites More sharing options...
