Can't Save To Hardware
pianojunky
They are edited tones.
The strange thing is the 'Save to Hardware' is not grayed out. It looks like I should be able to press it, but nothing happens.
I think I'll go the route of deleting the app and reinstalling it to see if that will clear things up.
May be a good idea to reinstall.  Be sure to save any favorite tones by publishing them.
Meanwhile, I just checked mine and I don't seem to be having your problems... most of the time.  Just for the record, here's what happens when it works correctly (on my iPhone 4S):  First,  go to "My Tones" (where the Save to Hardware is grayed out) and pick the tone I want to use. It gets highlighted in red and the "Save to Hardware" lights up. I tap "Save to Hardware" and it takes me to the "Hardware" page and I select one of the four presets. It immediately changes name to the new tone with a red banner. When I hit "Done", a timer spins for a couple of seconds and a green banner appears quickly at the bottom of the screen with a message saying "Save to Hardware was successful to location XX".
Now here's what strange...  sometimes when I go back to my "AMPLIFIED 150" from the main page to see if the changes took hold. It shows the correct tone patches including the new tone but when I back-track to "My Tones", I can't get "Save to Hardware" to work with another tone.  I think this sounds like the problem you're having.  Sometimes the "Save to Hardware" is lit, sometimes it's not.  Either way, it doesn't seem to work.  I usually close the app, go to "Settings", double-check the bluetooth connection, do the hokey pokey and turn the app back on.  Usually this fixes things.  So...  I think it's temperamental even when it's working correctly.
I am having this exact same issue. I've tried from both my ipad2 and iphone4 and in both cases the "save to hardware" is not greyed out but nothing happens when I press it. All other functions of the app and amp work fine. The firmware is the latest version. Short of deleting and reinstalling has anyone found another solution?!? Thanks.
