mcnugbugget Posted April 24, 2014 Share Posted April 24, 2014 Hey guys, I am wanting to record using my fender mustang amp (aswell as podfarm) and was wondering if i could use the xlr inputs on the ux2 or are they just for mics? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 24, 2014 Share Posted April 24, 2014 They are designed for mics but you can connect the output of any device into those inputs. Just be very careful with volume levels. The UX2 XLR's are expecting a low strength signal level (mic level). Your amp's output is probably at a different level; if it's adjustable try different settings. Be sure to start off with everything at very low output/input levels. Slowly increase both the amp's output level and the UX2 input levels until you find a good balance that gives you the strongest signal you can in to your UX2 without clipping or high noise levels. 1 Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 24, 2014 Share Posted April 24, 2014 +1 to silverhead What other outs do you have? I would be inclined to use the UX2 Line In, if you have no other outs you could use a XLR to 1/4" cable Also, I think some of the Mustangs have USB for recording. 1 Quote Link to comment Share on other sites More sharing options...
mcnugbugget Posted April 24, 2014 Author Share Posted April 24, 2014 thanks guys, it has a 3.5mm heaphone output and it can record via usb but there is no way to monitor and it is just a pain in the lollipop to use. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted April 25, 2014 Share Posted April 25, 2014 Don't mean to highjack the thread, but....I have. Line 6 spiderjam amp, and it has line out jacks (RCA) and i've wondered if that could be routed into the ux2. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 28, 2014 Share Posted April 28, 2014 Absolutely!! Run them to the Line In 1/2 Quote Link to comment Share on other sites More sharing options...
gary9605 Posted April 28, 2014 Share Posted April 28, 2014 Any way to get a CLEAN Pass through on Podfarm, if I wanted to use the settings and tone from the spider amp? Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 28, 2014 Share Posted April 28, 2014 For stereo, make a blank dual tone, pan A hard left and B hard right and do not put any effects or amps. Select Line1 Tone A and Line 2 for Tone B The one annoying thing is every time you open PF you need to reselect Line2 for Tone B. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted April 28, 2014 Share Posted April 28, 2014 Thanks, is there,however, some way to bypass the supplied amp setting.....or must I just use a "clean" setting. Reason I ask is the Clean don't really seem all that clean. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 28, 2014 Share Posted April 28, 2014 Delete any amps or effects in the paths. The only thing in the paths is the mixer block. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted April 28, 2014 Share Posted April 28, 2014 Again, thanks. I'll give it a try,? Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 28, 2014 Share Posted April 28, 2014 Are you using PF1 or 2. I can make a screenshot if you are still having a problem. Quote Link to comment Share on other sites More sharing options...
gary9605 Posted April 28, 2014 Share Posted April 28, 2014 PF 2, no real problems, was just interested in seeing how the connection should work. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 29, 2014 Share Posted April 29, 2014 Screenshot Quote Link to comment Share on other sites More sharing options...
