Using External Preamp
Zhorell
Novice question here; will the Effects works with an external preamp hook up in the loop return? I'd like to use the Power (Bogner) section with a tube (randall rm4) preamps..
If not? is there a way to bypass the digital amp modeling? connecting into guitar input to utilize the effects?
Please specify which SV you have. I will only comment on the SV MkII (Bogner) here.
1st and 2nd question: No, the effects will be bypassed.  [Edit from SV MkII Pilot guide, #14: Power Amp In – ...You can then use the POWER
AMP IN either as an input from another preamp or multi-effects unit like the POD X3 Live or as a “series effects returnâ€.]
3rd question: Anything connected to the guitar input will utilize the tube preamp and effects. It's ok to connect guitar style pedal effects to this jack (like distortion, wah, etc..)
  • 10 months later...
Hello! I like to know some technical parameter. I want to connect Gt8 multieffekt with "4 wires" and optimalize signal levels.
Please write for me:
Spider Valve MKII 100HD
Input level: ?dBu
and Impedance: ? Ohm
Pre out ?dBu, and imp.?Ohm
Power amp in ? dBu and imp
Thanks!
