Sign in to follow this
policart
Setting Tempo - Problems With Pod Hd Edit
Using POD HD Edit:
if I change tempo directly in the POD, then the Edit window is correctly updated;
if I use the Edit window to tap tempo or to scrolling tempo values, the tempo information is not correctly reflected in the POD.
Can you please confirm if you have the same problem?
Thanks
m.p.
Yup. I have the same problem. Haven't been able to find the time to start a thread about it. Thanks. Any help would be nice.
Unfortunatley, you (still) can't save the patch tempo via HDEdit.
It's a "known" problem and we've all been living with it for quite some time. <_<
The best method for me is to set the patch tempo with the tap tempo button, then save the patch directly on the POD.
I've not had any issues with what the latest update is supposed to fix but this "Tempo" issue wasn't one of them. :(
