Patrick507 Posted April 29, 2014 Share Posted April 29, 2014 Hi,I'm having a few problems with connecting these two devices.I've set the UX2 up to recognize the mic so I'm getting signal and can hear it but I have to crank the input gain to about 9 to get anything decent out of it! And I'm using the word "decent" very lightly.The resulting sound is full of reverb and noise. I'm wondering if this is a general problem when using a UX2 and a condenser mic.I've borrowed this mic off a friend who uses it with a Sapphire Pro 14 and he gets beautiful recordings. Clear and crisp.Do I need to amp the signal before it reaches the UX2 preamp?Any help is greatly appreciated ThanksPatrick Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 29, 2014 Share Posted April 29, 2014 Have you engaged the phantom power on the UX2 (the +48v button)? Condenser mics need this. Quote Link to comment Share on other sites More sharing options...
Patrick507 Posted April 29, 2014 Author Share Posted April 29, 2014 I have, I'm getting signal into the interface and out again, its just muddy and distant like theirs a large hall reverb on it. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 29, 2014 Share Posted April 29, 2014 Are you running Pod Farm to process the incoming signal? If so, apply one of the mic preamps (see factory vocal presets). Quote Link to comment Share on other sites More sharing options...
Patrick507 Posted April 29, 2014 Author Share Posted April 29, 2014 Thanks for the help. Im at work at the moment so I'll do it when I get home.Will adding a software mic preamp work?Im worried that it will only increase the noise that's already present on the line and make the insane reverb worse? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 29, 2014 Share Posted April 29, 2014 Yes - it should work. Using the software mic preamp means you will not have to turn the UX2 mic input volume up so high; it will take a much lower (less noisy/reverby) input signal and boost/process it internally without adding the noise. 1 Quote Link to comment Share on other sites More sharing options...
Patrick507 Posted April 29, 2014 Author Share Posted April 29, 2014 @silverheadI shall try that tonight and let you know. Thanks for the help Quote Link to comment Share on other sites More sharing options...
