Creating Tones In Line 6 Pod Hd 500
grahamm
Hi
I have tried to create tones offline from some patches from my Line 6 pod X3 by using LINE 6 POD HD 500 edit but when I have gone to load and sound check they load okay but zero sound. I cannot see where to double check all sound levels are open are not silenced. Is there anything else I should check?
All the best
G
Hi
I appreciate I am highj-acking this thread but I have only had the HD500 about a week but I cannot seem to navigate around the user presets and set lists etc without having to connect my laptop and use the HD 500 Edit . Is that normal as I cant see anyway of navigating as it seems if I am in SET LIST 1 for example I can switch between only those patches only and not bank up or down into the other set lits or fixed presets via the pedal board or the Home screen ?
Help?
Apologies in advance if I am being thick
All the best
G
Press the big knob to the left of the screen, the one that has "presets & press for setlists" wrapped around it, then turn it to select the list you want then press the enter button to the upper right, After that press the view button to get back and now you can press the up and down bank footswitches to navigate the list you chose.
Looks like you responded in the wrong thread?
