lou_kuehl Posted April 24, 2013 Share Posted April 24, 2013 Hello, I'd like to place the power-amp from a marshall into the FX loop block, do I just run the speaker cable from the amp into FX return on HD? Good call gentlemen, Most would say ignorance is stifling, I find it liberating. I was thinking about the sig chain. When using a full amp the mods come after power amp (I would think this better for plugging into line level/-10db?) When using pre-amp, mods are before power-amp (I would use +4db amp setting?). Now back to my ignorance, which chain is most practiced? Quote Link to comment Share on other sites More sharing options...
IncredibleOLF Posted April 24, 2013 Share Posted April 24, 2013 dont do this !!! - it will sure kill your POD...!! search for infos on the 4CM and howto... 1 Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted April 24, 2013 Share Posted April 24, 2013 "http://line6.com/support/docs/DOC-2112">http://line6.com/support/docs/DOC-2112 for more info, go to top right hand corner of the page and select SUPPORT. then go to KNOWLEDGE BASE. then scroll to CHOOSE A FORUM. then select POD FORUMS. the select POD HD. from there you can select USER DISCUSSIONS or DOCUMENTS.but there must be an easier way to get there, i just don't know how</p> Quote Link to comment Share on other sites More sharing options...
jimsreynolds Posted April 26, 2013 Share Posted April 26, 2013 Listen to IncredibleOLF! If you plug your power amp into your POD using the speaker jack you will destroy the pod. I think you are misunderstanding how 4CM works. Take a look at the document here for more information --> http://line6.com/support/docs/DOC-2522 What you can do is plug your pod into the power amp input. This is a standard setup with POD, used with the 'Combo Power' and 'Stack Power' modes. 1 Quote Link to comment Share on other sites More sharing options...
