anouchirvan Posted May 15, 2014 Share Posted May 15, 2014 Hi, For now my PC is optically connected to my Amp (for movies and musics) but the UX2 (on the same PC) is analog-connected to my Amp. I switch to PC's SPDIF sound card as default PC sound for movies and music and I switch to UX2 sound card as default PC sound every time I want to use UX2 for playing guitar or mixing/recording. Of course each time I select UX2 or PC's SPDIF, I also have to switch to the right input in my amp. What I want to do is just use UX2 as default PC's sound card all the time, yet be able to play guitar and/or listen to Dolby sound out of the PC. That's stop switching between sound cards on the PC or input on my Amp!!! Is it possible ? thanks Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 15, 2014 Share Posted May 15, 2014 I'm pretty you the UX's S/PDIF will only have stereo info. Are you running more than 2 speakers? Quote Link to comment Share on other sites More sharing options...
anouchirvan Posted May 16, 2014 Author Share Posted May 16, 2014 I'm pretty you the UX's S/PDIF will only have stereo info. Are you running more than 2 speakers? Yes I have two floor-standing and two surround. When I play guitar (with UX2) or when I listen to PC's music I use stereo but for movies out of the PC I'd like all my 4 speakers to be used. If the SPDIF outputs what is coming from PC, then it should support multichannel dolby although UX2's input (guitar&mic) are all stereo. The info isn't in the manual. Where can I find it ? Quote Link to comment Share on other sites More sharing options...
Triryche Posted May 16, 2014 Share Posted May 16, 2014 Assuming your amp/receive decodes Dolby Digital, just try it and see. Most receivers that decode discrete surround should display the incoming format. Quote Link to comment Share on other sites More sharing options...
