astarothreaper Posted June 4, 2014 Share Posted June 4, 2014 As the title says, Does the clean channel really take external distortion well?. I am willing to buy 15W or 30W but puzzle in this case. Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 5, 2014 Share Posted June 5, 2014 I'm not sure what you really mean. Generally, you do not want to combine an external distortion pedal with an internal-to-amp distortion because distortion X distortion sounds bad. All Line 6 amps can be adjusted for minimal 'drive' and any FX distortion can be turned off. Quote Link to comment Share on other sites More sharing options...
astarothreaper Posted June 6, 2014 Author Share Posted June 6, 2014 Thanks for replying. I get your point. Also I do know that the amp has built-in distortion effects. But still I am curious, because if I want to use any external pedal (either distortion or any other) so that will sound good with this amp or not (With the clean channel)? Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted June 9, 2014 Share Posted June 9, 2014 It's done all the time! Only you can judge if the sound is what you want. Quote Link to comment Share on other sites More sharing options...
jak_E_lee Posted June 10, 2014 Share Posted June 10, 2014 personally these don't require an external pedal like a boss pedal,the built in distortions are well up to the job. Quote Link to comment Share on other sites More sharing options...
Atomant669 Posted July 15, 2014 Share Posted July 15, 2014 Am planning to run my boss me-80's distortion on my spider 75 just to see how it sounds like :P Quote Link to comment Share on other sites More sharing options...
