berkleegrad Posted June 16, 2014 Share Posted June 16, 2014 figured this has been answered before - just can't seem to find it in my search... Can the HD 500 be used to switch on and off the reverb on an amplifier? My (ValveTrain) amp accomodates a 1/4" jack and it would be helpful, to be able to asign a footswitch to turn that on and off (as well as maybe turn of the digital reverb). Please note that this is analog and not MIDI switching... thanks in advance, -Rick Quote Link to comment Share on other sites More sharing options...
radatats Posted June 16, 2014 Share Posted June 16, 2014 Unfortunately, no. There is no capability to provide that type of switching for effects or channels... Can the HD 500 be used to switch on and off the reverb on an amplifier? Please note that this is analog and not MIDI switching... 1 Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted June 16, 2014 Share Posted June 16, 2014 You can turn off your Amp's Reverb and use one of the reverb models in the pod. Then you can turn that on and off. The Pod reverb models are very good. Quote Link to comment Share on other sites More sharing options...
berkleegrad Posted June 20, 2014 Author Share Posted June 20, 2014 Radatasts and Charlie_Watt thank you both for taking the time to reply to my query... sort of figured as much about the analog switching; but, it is always nice to have another confirmation (espcially when dealing with the ways of the POD) Yes, the POD HD's reverbs are indeed pretty good; but, every now and then, nothing is quite like a 'very good' spring reverb (which this amp has - it sort of blooms behind the note after you play it very nice). Plus I would free up a little processor headrom for other effects ;) again, thanks! , Rick Quote Link to comment Share on other sites More sharing options...
dbagchee Posted June 20, 2014 Share Posted June 20, 2014 I'm thinking about getting one of these and hooking the Pod via midi to be able to switch my amp channel and reverb with a patch change: http://www.voodoolab.com/controlswitcher.htm Quote Link to comment Share on other sites More sharing options...
