mostlyemptyspace Posted June 22, 2014 Share Posted June 22, 2014 Hi all. I recently bought a used PODxt. It works fine, and I've been enjoying playing with it. I found some tones on CustomTone that I wanted to try out, so I downloaded and installed Monkey on my Windows 7 laptop. I registered my product, updated to the latest drivers, updated the PODxt to the latest firmware, and installed Gearbox. I then ran Gearbox and loaded up the l6t file. It appears to have detected the PODxt just fine, because when I load Gearbox and open up the Tonelocker, it shows the PODxt in the bottom right corner. If I load up Gearbox without the PODxt turned on, it will tell me it can't find any devices, so this tells me that part is working. So, the problem is that Gearbox doesn't seem to be able to read from the PODxt. In the lower right corner it says PODxt, Memory > All, and underneath that it says (Unavailable). If I hit the Refresh button it says "Updating..." and in the middle where it says Transfers it says "Getting Tone Names... 0%". Then after a few seconds, it just goes back to saying (Unavailable). The four buttons to transfer files to and from the device are greyed out and I can't copy anything. Also, in the bottom right corner, it shows an icon of the PODxt with a yellow question mark over it. If I hover over it it says "This icon shows the status of the USB connection to your hardware." That question mark tells me something is wrong. I've attached a couple screenshots. Any ideas? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted June 22, 2014 Share Posted June 22, 2014 If you look at Monkey it's saying it can't see the PODxt, so I'm wondering how you updated it? The problem is your computer is not seeing the Podxt at all, so naturally neither will GearBox. Check your Pod's firmware manually as you may have an early version that cannot be updated by USB. Also try using another USB port and always connect diretly to the computer, not via a USB hub. To check your version: 1. Push the tuner button on your pod 2. Use the effects knob to scroll through to the last screen. 3. On the last screen you will find the PodXT version. If it is a low version like 1.01 you need to flash via MIDI. Quote Link to comment Share on other sites More sharing options...
mostlyemptyspace Posted June 22, 2014 Author Share Posted June 22, 2014 Ugh.. yeah it says POX XT Version 1.01. And I don't have a MIDI cable. So that means no patches for me? That's really lame. So why would this thing be made with a USB port, but the out of the box firmware doesn't support USB? Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted June 22, 2014 Share Posted June 22, 2014 When it was orignally released the PODxt's USB port functions hadn't been finalised. Later firmware updates made the USB functional and later Pods came with full USB ability as they had later firmware. Once updated via MIDI the USB port will become functional. You can buy the recommended MIDiSport Uno to do this - cheapo no-name brands tend not to work. Do you know anyone with MIDI (say for keyboards) as this would obviously save you money? Quote Link to comment Share on other sites More sharing options...
mostlyemptyspace Posted June 23, 2014 Author Share Posted June 23, 2014 So I do have an M-Audio Fasttrack Pro. This has MIDI ins/outs and connects to the PC via USB. Could I plug the PODxt into the MIDI port, and then connect it to my laptop's USB port to update the firmware? Or do I have to buy the MIDI to USB thingie? Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted June 23, 2014 Share Posted June 23, 2014 The M-Audio Fasttrack you have should work fine. After the update you won't need it again. Quote Link to comment Share on other sites More sharing options...
