topher10 Posted June 30, 2014 Share Posted June 30, 2014 I have several tones that I like, but they come with one of the effects (delay) tied to the FX knob. For instance, the mix setting is tied to the FX knob, but set to fairly low. It feels like the delay ignores the setting of the FX knob unless I then turn the FX the knob. So the result tends to be that I dont get any delay unless I bend down and turn the FX knob, which I do not like. I would like to disconnect this link, so that I can set the delay and it work exactly as I want when I activate the tone and not be influenced by the FX knob. Does anyone know how this works in the app, because I cannot figure how to link or unlink a setting to the FX knob. It might be nice to connect certain effects to the FX knob, although I am not sure why. Perhaps I am also not thinking correctly. Secondly, I also have questions about tap tempo as it relates to the delay. When you first activate a tone, what is the default for the delay tempo? Is it the delay time set in the tone parameters, or is it the delay time that has been set by tapping? To put it differently, if I switch tones mid song, do I have to retap the delay each time, or does the tapped tempo stay across tones. Is there a way to define this in the settings? Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 30, 2014 Share Posted June 30, 2014 You cannot disconnect the FX knob link per se, you can only reassign it to another parameter. But you should be able to adjust all the settings via the app and then save it to the hardware (and/or MyTones). I will look into the Tap Tempo behavior, but I think it defaults to the time value set in the preset. Quote Link to comment Share on other sites More sharing options...
topher10 Posted June 30, 2014 Author Share Posted June 30, 2014 OK. I have tried and tried to move the fx icon. For the tone I am thinking of its clearly on the 'mix' bar in the delay section, but I don't now how to move it to another bar. I also tried to activate the fx icon for a different patch, but could not understand how to do that either. So right now i have no idea how to unassign or reassign that Fx knob link, and so all i know to do its create a tone from the ground up to replicate everything just without that Fx knob link. One option I just thought of would be to increase the delay %Mix up from 0% to say 20% as the default, and then save that again. Then its possible that by default it would have 20% mix without me messing with the fx knob, which would work also. I will test that. It just seems unintuitive for the Fx knob to not actually control the parameter its linked to until you slightly turn it, at which point it it gains 100% control. I am sure there is a reason I don't understand. Quote Link to comment Share on other sites More sharing options...
Triryche Posted June 30, 2014 Share Posted June 30, 2014 One option I just thought of would be to increase the delay %Mix up from 0% to say 20% as the default, and then save that again. Then its possible that by default it would have 20% mix without me messing with the fx knob, which would work also. I will test that. Yep, that's what I was getting at regarding adjusting settings and saving it to the hardware. To reassign the FX knob, tap and hold it in the app. Quote Link to comment Share on other sites More sharing options...
topher10 Posted July 1, 2014 Author Share Posted July 1, 2014 Just confirming that the above works. Hold down the empty space beside the bar with the Fx logo, and it will bring up the option of moving it to another parameter. However, I left the Fx knob option there but increased it to 12% mix and now I always have a little delay without having to mess with the FX. So many options its hard to get a handle on them all. I could play for hours just with all the delay settings. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 1, 2014 Share Posted July 1, 2014 What would be cool is to have the ability to assign the FX to the pedal allowing you to change a setting on the fly. I submitted the idea to IdeaScale. http://line6.ideascale.com/a/dtd/AMPLIFi-FX100-Assign-Pedal-to-Tweak-Function/626369-23508 Quote Link to comment Share on other sites More sharing options...
topher10 Posted July 7, 2014 Author Share Posted July 7, 2014 I would also like this. I would let it control the gain/drive for a stomp box or compressor effect, that way I could slowly dial up the crunch. That sounds interesting, at least. Quote Link to comment Share on other sites More sharing options...
