lanteraudio
Monkey hangs on scanning devices
Using latest version 1.67
HD500 Edit and the Audio-MIDI app working fine.
Anyone know how to solve this?
(of course I can check for updates manually, but WTF is Monkey for then?)
Good question. Probably for multiple Line 6 devices and it lets you know if an update is available.
I don't know if it is related but I cannot get my PC to work with the latest drivers.
If I uninstall the latest drivers and let the PC automatically install it then works but "device not connected" before doing this.
Hmm, will not install new drivers then for the time being.
Used older drivers, had my studio off for half a year due to moving to a new home.
Thanks for your answer bjnette!
Hi there,
I had the same problem with Monkey 1.70 hanging on start-up in "Detecting MIDI devices" phase. I did some trial and error tests, is definitely a bug (or incompatibility) in Monkey. I use WindowsXP still. It does not like USB audio devices. If you plug one in I am guessing it messes up some Monkey data cache or some windows registry settings. It will make Monkey scan for MIDI and hang. Removing the USB device will not help, once the harm is done, is permanent.
The only way I found to fix this is to uninstall Monkey then install first an older version (Monkey 1.33 from GearBox package). Version 1.33 is too old to use, it gives some server connectivity error (I think the client-server communication protocol was changed, cannot even login with 1.33), but it will not scan MIDI and will detect correctly the Line6 USB device, also I guess in the background restore settings for it in registry or whatever data cache.
If you then leave the Line6 USB device connected and just install Monkey 1.70 over the old version, it will work. It will start normally and skip the MIDI scan.
Here are the detailed steps tested by me:
Programs -> Line 6 -> Tools -> Line6 uninstaller - uninstall only Monkey 1.70
Disconnect any USB audio device. You can leave connected USB storage devices like an HDD.
Run GearBox 3.72 installer - install only Monkey (version 1.33)
connect the POD Live X3 or whatever when the installer asks for it.
Start Monkey 1.33 and try to connect to server (Note: it will ask as option to scan MIDI devices if device is not connected, but you should have the device connected in which case it will skip over MIDI scan).
Let it configure the POD device.
Do not allow to upgrade to new Monkey version
Close Monkey 1.33 and run the new Monkey 1.7 installer while device is connected to USB port. Run Monkey at the end of installation, it will not scan MIDI this time, it will work.
I'm having a similar issue in OSx. I'm getting no messages about why Monkey (v1.70) is hanging.
Anyone else experiencing this? Any idea if backtracking to an older version will help?
