Using Shortboard MKII to control external pedal?
Never plug proprietary cat5 cables into other mfg's equipment even if the jacks look identical and the plug fit (IIRC even some older L6 fbs are not compatible with the newer MFXs). The wiring can be used for completely different purposes (ie: phantom power) and 9/10 something will fry on one end or the other or both.
-B
