How do I get sound out of the HD500?
pkwon
I am very new to this and I am not a very smart person, but I have my HD 500 set up to my laptop and guitar, but I am not hearing any sounds coming out of it (and yes, the volume is up on my guitar, laptop, and HD500). I feel as if the answer to this would be something very simple.
Thanks in advance.
Thanks again, guys. I tried the headphones and didn't get anything. What's the type of cord I need to connect the HD500 to my amp? It's a Line 6 Spider IV, if that makes any difference.
If you are not hearing any sounds from headphones connected to the HD500 you should check your patch/preset settings. Make sure you have your Guitar connected to the Guitar In jack, and then make sure your preset is using Guitar as one of its Inputs. Also check the Mixer settings to make sure you don't have the levels set to zero.
If you disconnect the POD from your computer, do you hear anything through the headphones then? (Try with only the power cable, the guitar cable into "guitar in," and the headphones in the "phones" jack, and make sure the master volume control isn't down all of the way).
Or, what happens if you plug a 1/4" cable into the Left(mono) 1/4" out and run it into the 1/4" input of your guitar amp?
