Sign in to follow this
austinctu24
How to use the pedal on a 500x as an expression pedal
I'm trying to control the volume on the Octo reverb with the pedal. how do I set this up?
Just got a pod after using a M13 for years
In the Signal Flow View, select the Octo, then double-press the MOVE button. The Controller Assign screen is then displayed. Use the Multi-function Knobs 1-4 to select the Volume parameter, assign its controller (EXP1 or EXP2) and define the min/max values.
I think you need to use the MIX parameter, there is no VOLUME parameter for the Octo...
