GiorgioHild Posted August 3, 2014 Share Posted August 3, 2014 I will write in italian but if it was a problem I can reply in english.Salve ho acquistato 2 settimane fa il g30 e nei primi due live che ho fatto ho avuto problemi di perdita di segnale, in 2 ore di concerto almeno 10 dieci volte il suono è andato e tornato con pause di circa 1/2 secondi... Non pochi.... online non ho trovato nessuna lamentela al riguardo.. di cosa si tratta?? ci sono soluzioni? Quando avviene questo problema tutti i led sulla basetta diventano rossi per un secondo e poi tutto torna normale. Quote Link to comment Share on other sites More sharing options...
dboomer Posted August 3, 2014 Share Posted August 3, 2014 Try switching to RF1 mode www.youtube.com/watch?v=9faTTufsgvs Quote Link to comment Share on other sites More sharing options...
GiorgioHild Posted August 4, 2014 Author Share Posted August 4, 2014 Unfortunately, when I do as you instructed here, my G30 transmitter does not respond as this one. First of all, my LEDs don't blink. I cannot reach the point where it flashes once or twice. Blue remains consistent after this process. Quote Link to comment Share on other sites More sharing options...
GiorgioHild Posted August 4, 2014 Author Share Posted August 4, 2014 I saw that my firmware version is 1.02 and for this reason I can't switch to RF1. Is it possible that I have a signal problem for this reason? I've this problem also when I play alone at home so not with the other member of the group. Quote Link to comment Share on other sites More sharing options...
dboomer Posted August 4, 2014 Share Posted August 4, 2014 Units that old only work in RF1 mode and cannot be switched. Have you gone through the troubleshooting guide in the FAQ? Quote Link to comment Share on other sites More sharing options...
Mercurietto Posted September 12, 2014 Share Posted September 12, 2014 Ciao a tutti. Ho anch'io lo stesso problema con 2 Relay G30 acquistati entrambi in Agosto 2014 (uno per me ed uno per il chitarrista). Ogni tanto il segnale sparisce per un secondo ... Hello everybody, i have this trouble too. I bought 2 (two) Ralay G30 in August and sometimes the signal drop out for one second, then everything ok. Quote Link to comment Share on other sites More sharing options...
dboomer Posted September 12, 2014 Share Posted September 12, 2014 Have you tried switching them to RF1 mode as recommended above? Quote Link to comment Share on other sites More sharing options...
Mercurietto Posted September 13, 2014 Share Posted September 13, 2014 Thanks for your answer. I don't know the firmawe inside the RelayG30 but when i made the procedure as you described my blue led don't flash. 1) I turn on the power 2) the green led switched ON and the blue led swiched ON (it seems violet) 3) the green led swiched OFF and the blue led stay ON but became blu. As i wrote i bought two NEW G30 last month (August 2014). Is it possible that the firmware inside is 1.xx version ? Quote Link to comment Share on other sites More sharing options...
dboomer Posted September 13, 2014 Share Posted September 13, 2014 Do both units have the same turn on sequence? What are the serial numbers? When you say G30, we are talking about complete systems,correct? Quote Link to comment Share on other sites More sharing options...
Mercurietto Posted September 16, 2014 Share Posted September 16, 2014 Hello DBOOMER, yes, both units have the same turn on sequence. These are my serial numbers: System: R6G2M6427002929 Transmitter: R6T0M6427007344 Receiver: R6R0M6427018111 In this moment I have not the other serial numbers (I gave the other ReayG30 to my guitarist) Could you tell me my firmware using the serial numbers ? Regards Quote Link to comment Share on other sites More sharing options...
Mercurietto Posted September 17, 2014 Share Posted September 17, 2014 The other serial numbers (RelayG30 Nr.2) : System: R6G2M6427000192 Transmitter: R6T0M6427007924 Receiver: R6R0M6427006682 Every time the signal drops out, the three green leds (signal leds) are changed from all illuminated to all off (just for 1-2 seconds), then they changed back to all illuminated. Regards. Quote Link to comment Share on other sites More sharing options...
dboomer Posted September 19, 2014 Share Posted September 19, 2014 Those serial numbers are flashed with V2.x firmware. I'm alsmost certain that your problems are wi-fi related because you are in RF2 mode. Please watch the video again and switch them to RF1 mode. Quote Link to comment Share on other sites More sharing options...
Mercurietto Posted September 23, 2014 Share Posted September 23, 2014 I'll watch the video again. However I'm going to contact the seller this Saturday. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Mercurietto Posted October 9, 2014 Share Posted October 9, 2014 Hello DBOOMER, the two RelayG30 were be replaced from the seller. The new Relays are perfect. I think the old one were flashed with V1.xx firmware (instead V2.xx). Thanks for your support. Quote Link to comment Share on other sites More sharing options...
riccardoguitar Posted October 25, 2014 Share Posted October 25, 2014 Hello DBOOMER, I have the same problem, already seen the video on youtube and already tried the trick, but it doesn't works, the blue light doesn't flash. Please, could you tell me if my system has the firmware V1 or V2?System: R6G2M6427004282 Trasmitter: R6T0M6422021517 Receiver: R6R0M6427017176 Thank you Best regards Riccardo Quote Link to comment Share on other sites More sharing options...
dboomer Posted October 27, 2014 Share Posted October 27, 2014 where did you purchase the system? Quote Link to comment Share on other sites More sharing options...
riccardoguitar Posted November 2, 2014 Share Posted November 2, 2014 Hi DBOOMER, sorry if I answer so late..I bought it from thomann Quote Link to comment Share on other sites More sharing options...
dboomer Posted November 5, 2014 Share Posted November 5, 2014 I can't check those serial numbers as they were shipped directly to EU. You'll have to check with your dealer. Quote Link to comment Share on other sites More sharing options...
riccardoguitar Posted November 5, 2014 Share Posted November 5, 2014 Thank you anyway DBOOMER, I'll write to the thomann's customer service. Quote Link to comment Share on other sites More sharing options...
madalf Posted April 2, 2016 Share Posted April 2, 2016 Hello DBOOMER, I seen the video on youtube and already tried the trick, but it doesn't works, the blue light doesn't flash. Please, could you tell me if my system has the firmware V1 or V2? Trasmitter: R6T0M6315004374 Receiver: R6R0M6315001281 I don't know the construction's year because I bought it used. Thanks. Quote Link to comment Share on other sites More sharing options...
