Sinestic Posted August 6, 2014 Share Posted August 6, 2014 Hello , The last month i played in my home with spider valve mk II hd100 and after playing at very moderetely volumes as usual i cut power from it and i covered it with a bed sheet. A few day ago i power on it ,take a few second to heating valves with standby on, but all the valves did not work ! I always use a current-voltage stabilizer so it is impossibile for it to take some current-voltage jump and during this month never have touched it , so it's impossibile to take account of physical damage. All the valve doesn't not work at all, very strange. The amplifier hardware works very fine, all the lights are on , but the valves are not. I use it infrequently and at minimum volume, so although i buyed it 3 years and half ago it's strange that all the valves stopped to work suddendly. The last time i've played it there was a great sound, no oscillation in volume , great basses and dynamics. Please help me .. Quote Link to comment Share on other sites More sharing options...
jjack972 Posted August 8, 2014 Share Posted August 8, 2014 Check the fuse in the back? Quote Link to comment Share on other sites More sharing options...
Sinestic Posted August 8, 2014 Author Share Posted August 8, 2014 As i said , i use a Voltage-current stabilizer so it's impossible for the amp to take a V-A jump. However i checked the main fuse and the tube fuse and they are perfect... Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted August 8, 2014 Share Posted August 8, 2014 must be the transforner Quote Link to comment Share on other sites More sharing options...
Sinestic Posted August 8, 2014 Author Share Posted August 8, 2014 Seriously ? usually do the valves broke ? e.d. all the valves suddendly stop or it's possible that only one valve stops and the other continues to work ? Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted August 8, 2014 Share Posted August 8, 2014 the transformer supplies power to the tubes for heater and bias. you have to check input and output. i'm just guessing as to what the fault is. could be just a broken wire :unsure: Quote Link to comment Share on other sites More sharing options...
Sinestic Posted August 8, 2014 Author Share Posted August 8, 2014 Tomorrow i'll check the transformer..looking at the amp from the front, is the right transformer or the left transformer ? Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted August 8, 2014 Share Posted August 8, 2014 should be the transformer closest to the power tubes Quote Link to comment Share on other sites More sharing options...
Sinestic Posted August 9, 2014 Author Share Posted August 9, 2014 It seems impossible to open the black chassis on which are mounted. Monday I'll call an expert tech.. I hope and pray :lol: Quote Link to comment Share on other sites More sharing options...
spaceatl Posted August 21, 2014 Share Posted August 21, 2014 There are two fuses inside on the amplifier board...One is for the heaters and the other is for the plates...Last time my mark II blew a power tube it took the plate fuse with it...fuses on the back were fine...If you are not seeing the heaters, it could be the heater fuse, but I tend to think it would be rare that one would blow... Quote Link to comment Share on other sites More sharing options...
zoomtoob Posted March 12, 2023 Share Posted March 12, 2023 There are two inside the spider valve hd100 mkii head?? Isee one 1A slo blo Quote Link to comment Share on other sites More sharing options...
