Sign in to follow this
austinctu24
Is Their Anyway To Add Expression Pedals To An Effect In The Pod HD Edit?
The pedal on the HD boards can be assigned to control most any feature of an effect. In the edit program you would assign it from the controller window.
Trying to figure this out! Thank yoU!
You can map the expression pedal to control some parameters of your effect. Highlight the effect you want to be controlled with the expression pedal and double press the Move button. Then from the display you will see from the LCD, you can assign your effects' params to the expression pedal.
BTW, I know my avatar says only 7 posts. I have used PODs since the 2.0 version. I just now got around to actually joining the forum. I don't know every little nook and cranny of these products but I am by no means a beginner. I will try to help as best I can.
To do it in HD Edit, cick on the controller tab. Select the effect under "model", select the parameter you want to control, then select EXP-1 or 2. Then set the min and max.
