Tube screamer -> Amp head -> Pod ux2, can it be done?
Hi. I need some help. I've been using podFarm for a while and seen some great results for metalcore music. Recently I purchased an ibanez ts808 tube screamer and removed my tube screamer simulation from my podFarm tone to see if it gave the guitar a more realistic sound. I was happy with the result. I am now looking to buy an amp head So now I have two questions which I need help on. Can I have a chain of real tube screamer -> real amp head -> pod, and remove the amp head from my pod farm tone to give the guitar an even more realistic sound, as the only thing simulated would be the speaker cabinet? If I can do this can someone explain as simply as possible the way to do it, as I am a noob. My second question is what is the cali diamond plate amp head meant to be like in real life amp heads, I have £1000 to spend and want like a real version of the cali diamond plate, any suggestions?
Thanks
If the amp has a line out output you could do it, but you will not get the same sound as if the power output of the amp is driving matched speakers.
If the amp does not have a lineout, then you would need an attenuator box or DI box that can take a powered signal and convert it to line level.
