jbutler Posted August 28, 2014 Share Posted August 28, 2014 Anybody had much luck programming Leslie that actually sounds close to a Neo Vent or a Strymon Lex? Or even a Rotosphere or a Korg G4? I am a guitar thru Leslie addict, and having trouble programming the Pod to sound decent. Have resorted to using my Boss RT-20 in the efx loop (my awesome Lex was recently stolen) and it sounds a lot better than any factory preset leslie patches, but I would rather stay in the box and not have an external pedal, and the extra D/A and A/D conversions. Having a patch that could have programmable speed ramping would be awesome, but changing speed manually with expression pedal would work. But the most important thing is getting the doppler tone correct in the first place. Quote Link to comment Share on other sites More sharing options...
Steelmaster Posted August 29, 2014 Share Posted August 29, 2014 I'm with you. I use a Leslie 825 in my full rig, but I have to put up with the lackluster simulation in the 500X when I don't have room. As they say, once the drummer kicks in, what does it matter ;~) 1 Quote Link to comment Share on other sites More sharing options...
maxnew40 Posted November 5, 2014 Share Posted November 5, 2014 I know this is a bit of an old topic. A real Leslie is typically used in place of an amp. I need to experiment but it doesn't seem to be very realistic to try and put the Leslie before or after an amp. I think you might want to start with no amp and use the Leslie as the amp. -Max Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 5, 2014 Share Posted November 5, 2014 I know this is a bit of an old topic. A real Leslie is typically used in place of an amp. I need to experiment but it doesn't seem to be very realistic to try and put the Leslie before or after an amp. I think you might want to start with no amp and use the Leslie as the amp. -Max A really Leslie is an amp, but the effect on the HD was designed to work with an amp model. I don't think you'll have much luck having it sound right without one. There's nothing stopping you from trying it, though. Quote Link to comment Share on other sites More sharing options...
maxnew40 Posted November 5, 2014 Share Posted November 5, 2014 I guess you guys missed the tone building video where they were building a Jimmy Page tone and had a foot switch activate the leslie and at the same deactivate the amp model. It seems to sound pretty good in the video. -Max Quote Link to comment Share on other sites More sharing options...
evh5150combo Posted November 6, 2014 Share Posted November 6, 2014 Yeah, I love the dimension. I use it everytime I need a chorus and for the pink floyd stuff you can set the mix properly and simulate the Doppolas effect. What are your settings for this song? Quote Link to comment Share on other sites More sharing options...
evh5150combo Posted November 6, 2014 Share Posted November 6, 2014 I see that we are almost neighbors (about 30 Km).. nice place Castel San Pietro Hahaha, è vero! Grazie mille. Quote Link to comment Share on other sites More sharing options...
sidroe Posted November 6, 2014 Share Posted November 6, 2014 Eric Clapton has used a Marshall head to push his leslie cabinet forever. I've used leslies for many years on guitar using Fender amps. Back in the day, a little 40 watt leslie could not compete with Marshall stacks for stage volume. You had to resort to micing which became the norm but for a long time a lot of guitar players simply hooked the speaker to hot guitar tube amp and pumped that volume in to the rotating drums. I even had a guy one time that was using stereo leslies, one on each side of the stage. He had cut out a square in the plate and mounted a 100 watt EV solid state amplifier. All he had to do was run the extension cab lines to the other side of the stage. Just saying where there's a will, there's a way. Quote Link to comment Share on other sites More sharing options...
Metalchef Posted November 9, 2014 Share Posted November 9, 2014 Ive always had decent results with the leslie mod and its injected into alot of my blues tones. Its as simple as fiddling with the settings and getting your brain into the less is more mindset. One thing ive learned with the POD is never Trust a DEFAULT SETTING . Quote Link to comment Share on other sites More sharing options...
