EarthyMusic Posted September 10, 2014 Share Posted September 10, 2014 I'm having trouble with a buzzing sound on my HD 500. On a clean setting, it's more of a hiss, but once you turn on distortion, it's more of a buzz (or buzz kill, as the case may be!). It seems like a grounding issue with the device. No matter where I'm playing--at home, in the rehearsal studio, or at gigs--it's the same thing. This leads me to think it's not a problem with the quality of the electricity. I play through a few different amps, from tube to solid state, depending on the situation. Always the same problem. Also, I still get it using different guitars--Les Paul or Strat, it's the same thing. The buzzing is worse when I have the USB cable connected. It's also worse when I use distortion--the more distortion, the worse it is. I was doing some searches on this, and I see that other people have similar problems. I've tried re-setting the global settings, but no joy. I'm using the 1/4" input. Anyone have any ideas? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted September 11, 2014 Share Posted September 11, 2014 Are you around something that may be injecting RF into the mix? I had this symptom once, reinstalled the firmware without saving patches and it was fine after that. Don't ask me why 'cause I don't know. Maybe a bad patch corrupted the brain. Quote Link to comment Share on other sites More sharing options...
EarthyMusic Posted September 11, 2014 Author Share Posted September 11, 2014 Thanks. I tried reinstalling the firmware, but it didn't work. As I was saying, I get this sound wherever I am so I don't think it's caused by RF interference from my computer monitor or something like that. Maybe there's a physical issue with my board? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted September 11, 2014 Share Posted September 11, 2014 Oh, it could be as simple as a bad cable, cable end, or jack. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted September 11, 2014 Share Posted September 11, 2014 Do you get the buzz when nothing is plugged in? Quote Link to comment Share on other sites More sharing options...
