Sign in to follow this
bluezboy77
mobile Pod App ios 8 Bug
upon updating to ios8 i have found out that mobile pod app has a bad bug, and is non operational.
The ipads keyboard is visible and will not dissapear making it impossible to use the app.
very Frustrating...
please fix soon !!!
I've done as you have directed and the keyboard is gone but now sonic port won't recognize my guitar signal nor will it load songs into the mobile pod. This is totally insane for those of us that rely on your products to make a living. I've now lost 3 days of work. What's the fix now?
I have the same/similar problem.
iPad Air iOS 8 with Sonic Port XV
mobile pod v.1.06.1f
Privacy ... microphone access allowed to mobile pod application
But still I get the pop up "Line 6 Device Not Found"
Clicking on the Line6 logo at the bottom the second line says Device: Device Not Connected.
Further Information:
After several tries to connect/disconnect, start/stop the application, turn privacy off/on I gave up and tried on iPhone 5s iOS8 same version of mobile pod.
There it was working immediately - though not stable, the app crashed twice after few minutes use.
The device was also successfully recognized by other apps (immediately with AmpKit, with some flaws by Amplitube) I was using before ...
I tried these apps then again on the iPad air, they were not working there like mobile pod before :-(
... so I would assume, that this is not an mobile pod issue, but a sonicport<->ipad issue,
... is there a firmware upgrade for sonic port XV available by any chance?!
Thanks for your support!
Hi all,
I'm having problems running Mobile Pod v1.60 on my iPad Air with iOS8.02.
The problem also happens on my iPod touch 4 th gen. With iOS8.02.
The mobile pod app crashes intermittently after 5 to 20 minutes of operation.
The Mobile Pod app locks up, and disconnects the Sonic port.
No other apps running.
None of the usual troubleshooting tricks works to fix this problem.
I am using a new Sonic port VX s/n (21)sp10m6433006835
The Sonic Port works reliably with other guitar sim apps and audio software.
It is ironic that it does not work well with Line 6 own application.
Thanks for your help with this
Dave
UPDATE:
after upgrading to iOS 8.02 and several restarts of iPad air it finally started working! mobile pod app version remained the same (1.6.0 ... application build and dsp engine v1.06.1f)
And it's working really fine with some other applications, too.
BUT, I was facing the same (described above) crashes of mobile pod app on the iphone 5s, too.
As I'm a bass player and mobile pod UNFORTUNATELY doesn't offer any bass amps (AFAIK) I'm using a different app without any issues.
This is bizzare!
I have exactly the same problem, my Ipad mini crashes, all the time when using Mobile Pod, and Mobile Pod seems very unstable, and so I read one or two of the above posts, and tried my Sonic Port VX with other apps, well actually only Garage Band on it's own, without using inter-app and so far it seems to be very stable.
So the problem seems to lie with Mobile Pod, so c'mon Line 6, get it sorted!
Alan
I have recently got the Sonic Port VX, and using it with my iPad Air and iPhone 6 16G, both are 8.0.2.  Seems mobile pod is not very stable with iOS8 (and I haven't had the luck to use it with iOS7 cos my devices are all upgraded before I got this nice Sonic Port VX...), I once in a live performance that mobile pod crashed, and the Sonic Port VX was "screaming" at very high pitch (yes, the noise was from the VX...).  I need to detach it with my iPad, and force stop the mobile pod....
Is there a fix that could save me from wasting $$ getting this VX but I can only put it somewhere in my garage?
There is a new issue occurring when Mobile POD stays connected to a Sonic Port VX for anytime between a few minutes and a few hours. We apologize for the inconvenience.
We are currently working on a fix for this bug.
bad news ... :-/
after another ios upgrade on the ipad, now iOS 8.1, mobile pod 1.6.3 (826) it's not working anymore.
BUT, on the iphone 5s it still is! so, the unit seems not to be broken.
Any firmware upgrades for SonicPort VX available in the meantime?
Does it help to connect both lightning and USB cable (for power?!)
I think I will open a support ticket now ...
Did you give Mobile POD access to the microphone after the iOS update? In settings- privacy- microphone- Mobile POD?
