Sign in to follow this
JEISEN
PAD button
On the Gear Box Gold plug in there is a PAD button on the front. It is not addressed in the .pdf.  Pressed in it sounds muted. Out it sounds louder. I've looked online for info-none. How should it be set for recording????? :huh:
You can use it either way. Usually I don't use the pad. If you have high impedance pick ups on your guitar or use a stomp box in front you might find yourself using it.
Thanks Brazzy-I just wanted to make sure. I should have mentioned it's for bass for now-guitars later. Bass-passive EMGs. Guitar active EMGs. I'll leave it out(off?)-it's LOUDER!! :D
Create an account
Register a new account
Sign in
Sign In Now
