JimNiven
No. effects in the signal chain (Amplifi 150)
From other posts, it seems that you can on have only one effect from each type/group of effects  at a time in the signal chain (i.e. one Stomp, one Mod, one Delay and one Reverb model). Can someone confirm if this is the case please. Or if it is possible to have more than one, how do you add two of each type of effects when editing / adding to a tone ?
Thanks
Jim
You can indeed have more than one type. The 3 effect blocks can be of any type.
But the number of total blocks is fixed.
For example, select an effect block, click to the left, then you should see Type which will allow you to change the type.
Thanks Uber Guru. Not quite the solution I had in mind but may well suffice in many/most cases. I see this substitution only works with four FX block types, viz: (1) Drives and Dynamics, (2) Mods, (3) Delays and (4) Filters, Synths and Pitch.  It does not work for the "Wah" and "Reverb" block types. Correct ??
jim
Create an account
Register a new account
Sign in
Sign In Now
