Sign in to follow this
rayg1952
Question About The POD X3
I bought a used POD X3 online and I probably will be getting it by end of this week. So the only way to create tones is to have the X3 connected to the computer with Gearbox is that correct, once you created your tones and save them I'm assuming there stored within the X3 as well within Gearbox, so when I disconnect the X3 from the computer the tones I created and saved are still within the X3. If I wanted to play my guitar with the X3 and with headphones without the X3 plugged into the computer can I do that.
You can edit the X3 directly without Gearbox. The X3 in theory never has to be connected to a computer for normal use.
Sit down with the manual to get a good grasp of the menus as there are a bunch of options. Gearbox just makes it easier.
-B
When using Gearbox, you must use the PUT command to send/store the current preset to the X3 device.
I have read some of the quick start and the advance guide. When I download and install Gearbox does it come with monkey.
Thanks everyone.
Nope, its separate. So is the License Manager and Pod Farm.
-B
