mcolquitt Posted October 20, 2014 Share Posted October 20, 2014 OK so here is my first official problem with my HD-500. (That I bought the first month they were available) I can no longer use the toe switch to select between exp-1 and exp-2. It had been getting more and more difficult to get it to actually click and now it is not operative at all. I wonder if there is some type of solution that doesn't involve taking it to be repaired. Does gunk or dust collect that can be blown out? Is this a ridiculous and wholly idiotic question? (well maybe that was overstating it, but you get the point... :) Thanks for any help you may be able to share. Quote Link to comment Share on other sites More sharing options...
mcolquitt Posted October 22, 2014 Author Share Posted October 22, 2014 give a look at the post linked here: http://line6.com/support/topic/2686-pod-hd500-expression-pedal-adjustment/ I don't know if also your problem could be fixed that way or not, maybe worth a try, I do not assume responsibility.. I will try that very thing tonight. I am hoping this does the trick. Based on what the guy who posted that described, his situation was identical to how mine is now. I am causiously optamistic. Thanks very much, hurghanico, this was exactly the type of thing I was hoping to find. You rock!! Quote Link to comment Share on other sites More sharing options...
