Main :: POD HD
HD400 vs HD300
by jhdesign on 2012-07-10 01:02:58.9010
A store up here in Canada has on sale the HD400 for less than the HD300.
I gave up on getting the 500 as it seems a bit too much of a learning curve. So I decided to get another 300 untill I saw the 400 on sale.
Is there any reason I should buy the 400 rather then the 300 ?
They both seem almost identicle except for the layout and a few extra effects.
As for Customtone presets. Does the 400 use the same as the 300 ?
Re: HD400 vs HD300
by mazuwa on 2012-07-10 03:12:21.3360
You can compare the 2 devices here:
http://line6.com/podhd/multi-effects/compare.html">http://line6.com/podhd/multi-effects/compare.html">http://line6.com/podhd/multi-effects/compare.html
As you can see it is not only less effects, it is also missing Send/Return path and no external expression pedal jack.
Yes, you can load HD300 files into the POD HD400, but only this one way.
If you can get a HD400 for less money it is a good offer.
(Currently only the HD500/PRO/BONE have firmware 2.02 with the new plexi lead and bass amp model, furthermore it comes with new cab deep editing.
We do not know how much the HD300/400 will get of it in the future (discussion: you have to buy what the device can do now, not in the future). Only HD500/PRO/BONE provide bi-amping, and free selectable effects (not only one effect out of one block), and some things more).
Re: HD400 vs HD300
by jimsreynolds on 2012-07-10 03:30:02.7500
What Mazuwa said.   Not much difference in complexity between the 300 and 400.  I would go for it!
Re: HD400 vs HD300
by TheRealZap on 2012-07-10 05:27:03.5080
i'd want the 400 over the 300 just for the ability to change preset banks without hitting 2 footswitches myself...
the extra fx and the fx loop are also considerable bonuses.
Re: HD400 vs HD300
by jhdesign on 2012-07-10 15:14:38.3330
Thanks for all the replies.
As long as I can use the Customtone presets made for the 300 on the 400, then it will be the 400 I'm buying.
Re: HD400 vs HD300
by spaceatl on 2012-07-10 16:40:07.2540
yep...that works...just loaded the HD300 patch Heavy Space into my HD400...
Re: HD400 vs HD300
by bclarke675 on 2012-07-11 06:09:37.0840
I'd love to have the additional effects, as well as not having to step on two switches to change banks!
Re: HD400 vs HD300
by jhdesign on 2012-07-11 12:49:56.9970
Thanks again all.
The 400 was purchased today.
Re: HD400 vs HD300
by spaceatl on 2012-07-11 14:40:06.5840
400 has quite a few little cool tricks...nice board...enjoy!
Re: HD400 vs HD300
by jhdesign on 2012-07-12 01:39:40.0200
A few tricks ? As compared to the 300 ? If I'm missing something, do tell.
I first bought the 300 last October and then sold it 2 months ago. I loved the simplicity of the Edit software and the board itself.
So far the 400 seems pretty much the same.
Thanks spacati
Re: HD400 vs HD300
by jhdesign on 2012-07-16 16:30:42.3970
Why is it that when I download effects for the 300, their is no “POD HD Edit” logo on the file, its just a blank document ?
Re: HD400 vs HD300
by TheRealZap on 2012-07-16 17:12:21.3750
because the file type is different... technically those files are meant to work with hd300 edit...
it just so happens that they also work with the hd400
Re: HD400 vs HD300
by bclarke675 on 2012-07-17 07:08:06.0260
You have to change the file type to ".h4e", instead of ".h3e".  It will recognize it then.
