In the process of trying to figure out what a 4 Band Shift EQ is, I put my HD500 on the test bench and measured the frequency response of ALL the EQs in the HD500. I thought you'd find it useful so I'm sharing the results here. For example, what does a 100% shift mean? What does 0% Q mean? And just where is Freq = 38% in the Parametric EQ? Did you know when you set 2.2kHz of the Graphic EQ to -12dB you'll get a +12dB boost (!) at 1kHz before it dips down at 2.2kHz? No wonder it didn't work very
