What would be best settings to use Pod Go to use as an interface only as I am running Helix Native   Found out that as an interface it works (sounds) better than just your usual interface so will keep it for that purpose only   Any thoughts on the best global settings for this purpose and would assume you just load a new blank preset and turn all effects off ?   I think its just wet signal to daw out of the box correct ?   Seem to have it working as such b
