Difference between Asio buffer size and ToneDirect buffer size?
clay-man
Buffer is your latency via POD , recording software and monitoring the result. Time in to time out.
As far as I am aware going by other interfaces Direct monitoring is listening or monitoring at the interface on the way in and not after the computer program.
You have a choice but to monitor already recorded material it has to do the round trip and this is known as full duplex.
Asio4all has a bad wrap in some circles interfering with other interface asio drivers and system functioning.
It pretty well makes any audio interface connected tot your computer a asio one and it can cause hell
if your device has its own drivers.a doubling up.
Not sure how it  is now but the general consensus was don't use .
It was originally used to make generic onboard consumer, non pro sound cards work in programs like cubase.
I know what latency is, but there are 2 buffer sizes in the POD configuration panel in control panel for windows.
One is labeled ASIO Settings, with a dropdown box with numbers 128, 256, 512, etc.
The second is a slider saying "extra small,  medium, extra large" with the title "ToneDirect & USB Audio Streaming"
They both seem to affect the latency.
As for ASIO4ALL, I know you're supposed to use the driver your device comes with, but like I said, I like to route to multiple outputs, something almost all ASIO drivers can't do, but ASIO4ALL can, with low latency results.
I use ASIO4ALL for streaming my guitar and music live.
The question is, why is there 2 buffer settings and not one in the Line 6 Audio control panel?
