chopshop7777 Posted September 21, 2013 Share Posted September 21, 2013 Hi all, just got my hd500x and I am pretty impressed with it however for the life of me I cannot figure out how to record it through protools, I am running the Digi 002 rack, I chose the pod as the main audio source and I still cannot engage record any help on how to set this up would be greatly appreciated. cheers. oh I got my guitar running through the pod as got the pod hooked up by way of USB to my pc and use the back of the pod for the 1/4 cables of the monitors. Quote Link to comment Share on other sites More sharing options...
bjnette Posted September 22, 2013 Share Posted September 22, 2013 Good onya. Great piece of kit and pushes above its weight for the dollars. First, while your USB connected install L6's Monkey, Drivers and edit software. You have to close out EDIT to use the USB as an Interface or use your 002 rack which you can connect via s/pdif or any analogue outs. Quote Link to comment Share on other sites More sharing options...
chopshop7777 Posted September 22, 2013 Author Share Posted September 22, 2013 Hi bjnette , thank you so much for replying, so the s/pdif will work ? cool , so in protools in the track input , you chose s/pdif instead of line input in ? thanks so much again. cheers. Ed Quote Link to comment Share on other sites More sharing options...
bjnette Posted September 22, 2013 Share Posted September 22, 2013 Yeah s/pdif is the way to go as the HD already coverts analogue to digital. If you go out the analogue outs the HD converts back to analogue and if going into your interface it has to convert again back to digital. Quote Link to comment Share on other sites More sharing options...
chopshop7777 Posted September 22, 2013 Author Share Posted September 22, 2013 Hi again bjnette, thanks for taking the time to reply once again. that's pretty cool I didn't know that's the converting process, I will try it out in a few hours and let you know. thanks so much again man. cheers. Ed Quote Link to comment Share on other sites More sharing options...
