piker Posted July 29, 2017 Share Posted July 29, 2017 Hi , I'm trying to install Firehawk remote from the app store onto my Ipad gen 3 device. The app itself can not be downloaded because it needs ios 10 or higher . Unfortunatly Apple ceased support for Ipad 2 , 3 for ios 10 so I can't upgrade . Line 6 claims it supports Ipad versions from ios 8 on .. Does anybody else has this issue and nows how to solve it ? Opened a ticket but can't wait for the weekend to pass ;-) By the way got remote installed on my iphone ( which has ios 10.x) and it works perfect . Just a tiny bit on the small side to use ;-) Cheers Quote Link to comment Share on other sites More sharing options...
suedehead99 Posted July 31, 2017 Share Posted July 31, 2017 I've got the Firehawk Remote app on my ipod touch and my ipad 2 (which stopped upgrading at ios9), no probs. Keep trying and let us know how you get on. And welcome to the forum! Quote Link to comment Share on other sites More sharing options...
piker Posted August 2, 2017 Author Share Posted August 2, 2017 Solved it . If a minimum IOS version is needed for an app, in that case Apple does not propose an app version downgrade that works with your IOS . Unless you have already downloaded it before . There are 2 ways of solving this . Either you download the app with an apple device which has the newer version of IOS and is under your apple ID . Or you download the app under itunes, under your apple ID, without connecting the 'old ' device . Once you have done either of these you can download the app with the older device over the appstore . It will then ask you to download a compatible app version. Click yes and there you have the Firehawk remote . @suedehead99 : No idea how you managed to install it unless you had it installed before line 6 released the new version . Thanks to google and howtogeek www.howtogeek.com/263568/how-to-install-older-versions-of-ios-apps-on-an-old-iphone-or-ipad/ Quote Link to comment Share on other sites More sharing options...
suedehead99 Posted August 2, 2017 Share Posted August 2, 2017 @suedehead99 : No idea how you managed to install it unless you had it installed before line 6 released the new version . I've had it for about 18 months so that's probably it. Quote Link to comment Share on other sites More sharing options...
