Pod HD300 volume cuts out
lkingdon
Every once in a while my HD300 volume drops off to about half the volume it was.  It does it on every channel.  I saved all my settings, re-set pedal to factory settings, re-booted power, re-calibrated volume pedal, nothing, still does it.  Leave pedal alone for a few days and try again and it is fine.  Sometimes play a entire gig, 2-3 hours no problems, sometimes play 15 minutes, problems.  Any ideas anybody?
  • 10 months later...
I'm having the same issue with my HD500. I connect it to my DT50 using the L6 Link and I don't know if its the DT50 or the HD500 which is causing the problem. And because it doesn't happen consistently every time its hard for me to pin it down. Did you end up fixing your problem?
