I have several presents where I want the volume pedal and the wah. When I add these blocks to the path it automatically assigns the volume to exp2 and Wah to exp1. To change between you use the toe switch on the pedal.
This is all good except as it's in volume mode as default I have to press the pedal all the way forward to activate the hidden toe pedal to get to the wah.
The problem is now I'm at 100% volume as I've had to push the volume pedal all the way forward to g
