guruvaiski Posted May 18, 2013 Share Posted May 18, 2013 Hi, My Line 6 FBV shortboard footswitch is damaged. I am thinking of buying a Roland FC 300 midi foot controller from a friend. Is Roland FC 300 foot controller compatible with Line 6 xt pro? Quote Link to comment Share on other sites More sharing options...
epiphany1415 Posted July 13, 2013 Share Posted July 13, 2013 Yes, it is. What you'll need to do is look in the Appendix of your POD's manual at the "MIDI codes" reference table. This will tell you the code to program a specific patch to a specific button. I.e., if you want the midi controller's first button to select 1A from the POD, the code you need to program on the midi controller's first button is "00." As well as using the midi controller to select presets/patches from the POD, you can also program a button to activate delay, mod, stomp without having to change your banks, as well. I.e. the midi code for "delay on/off" could be "58" (using a random number, this isn't the actual code). Say you're on bank 1A with no delay, hit a button with the "58" code stored and you could stay on 1A and just add a delay. Quote Link to comment Share on other sites More sharing options...
