laklandfan07 Posted April 5, 2020 Share Posted April 5, 2020 Hey I separate my signal path using a crossover putting distortions and my amp in Path A and compressed lowend in Path B. Because of my board layout i need to use a headphone out to send my dirty signal but I'm not sure how i can set this up. Is this possible? If so can someone share how step by step? Quote Link to comment Share on other sites More sharing options...
bassbene Posted April 6, 2020 Share Posted April 6, 2020 TL;DR: No, not with the HX Stomp. Long version: There is no option to route a path to a certain output directly. On the "bigger" members of the HX family you could choose which output type (XLR, 1/4") should be used as source for the headphone out. This allows you to route the dirty path to XLR only... but well. I guess this would also not fit into your pedalboard layout ;-) Besides that: On the bigger Helixes, the stereo separation is disabled at the moment when only one output jack is used. You might have to plug at least a dummy plug into the other output jack.. Perhaps its easier to find some millimeters of space to just go for the normal R/L outs on the top. Quote Link to comment Share on other sites More sharing options...
