Polisonic Posted April 2, 2023 Share Posted April 2, 2023 Lost mine recently and ordered a replacement, which was not compatible. Anyone know where I can find either the correct power supply for Version 2, or the correct replacement number so I can search for and order it online? Quote Link to comment Share on other sites More sharing options...
liet_ Posted April 5, 2023 Share Posted April 5, 2023 Hi, My POD 2.0 power adapter reads: LINE 6 PART NO: 11-32-0932 AC/AC ADAPTOR MODEL: MKA-091200GS INPUT: 230V 50Hz / OUTPUT: 9VAC 1200mA MADE IN TAIWAN I've also used my POD 2.0 with my PODxt power supply, which reads: AC/AC ADAPTOR MODEL: SY-09200A-GS PART NO: 11-32-0003 INPUT: 230V~50Hz OUTPUT: 9V~2000mA 18VA MADE IN CHINA Hope this helps! - liet_ Quote Link to comment Share on other sites More sharing options...
liet_ Posted April 5, 2023 Share Posted April 5, 2023 According to https://line6.com/support/page/kb/general-faq/power-supplybattery-specs-and-faq-r445/, you're looking for a PX-2g power supply. Something I've also come across is the following table, which lists some other model/part numbers: Of course, buying off the internet you may run into power supplies of dubious quality, make sure to check the customer feedback. Quote Link to comment Share on other sites More sharing options...
Polisonic Posted April 5, 2023 Author Share Posted April 5, 2023 Thanks, liet_! Appreciate your help! Quote Link to comment Share on other sites More sharing options...
Mr_A_Standard_7 Posted January 9, 2024 Share Posted January 9, 2024 So you said that you're running your POD through 1.2A supply. Would 1A be enough? Because I know guy who has got those lying around, and would like to know if it's possible to run POD through it, before dismembering (because the connector is probably different). Thanks in advance. On 4/5/2023 at 3:03 PM, liet_ said: Hi, My POD 2.0 power adapter reads: LINE 6 PART NO: 11-32-0932 AC/AC ADAPTOR MODEL: MKA-091200GS INPUT: 230V 50Hz / OUTPUT: 9VAC 1200mA MADE IN TAIWAN I've also used my POD 2.0 with my PODxt power supply, which reads: AC/AC ADAPTOR MODEL: SY-09200A-GS PART NO: 11-32-0003 INPUT: 230V~50Hz OUTPUT: 9V~2000mA 18VA MADE IN CHINA Hope this helps! - liet_ Quote Link to comment Share on other sites More sharing options...
