bartcwise863 Posted July 9, 2024 Share Posted July 9, 2024 Not very long ago, I purchased an XD-V75 Transmitter. It worked well, until yesterdayl. The issue is that the door doesn't close far enough to make a connection to the batteries. If I press on the top, it will make a connection. But the connection is lost the second I remove my finger. Picture #1: This is the XD-V75. The battery door has been shut, and the level slid all the way to the left. You can see the gap between the battery door and the body of the transmitter.Picture 2: This is a RELAY TBP12 TRANSMITTER. You notice how tight the fit is. This unit (and all the others I have) work flawlessly. Picture 3: The battery compartment of the XD-V75. Not a great picture. But when I look in the battery compartment and look at the connectors on the floor of the compartment, the one on the right seems to be smashed a bit. I thought about putting some shims of some sort into the compartment to see if I could create a connection when the door was closed. But I figured the unit is still under warrenty and they will do a better fix than I can. Any thoughts on how to fix it (w/o damaging it further)? Thanks, Bart Quote Link to comment Share on other sites More sharing options...
