Using Octave Effect on E & A strings only?
JazzyJ1234
The Helix Stomp has a massive list of effects and I'm hoping to emulate my acoustic guitar pedalboard but have come 'stuck' regarding an Octaver.
My pedalboard is ToneDexter (IR) -> Diamond Comp (Optical Compressor) -> Para EQ (parametric EQ) -> Boss OC3 (Octaver) -> TC Delay (Slapback Delay) -> Hall Reverb.
All of this seems possible in the HX stomp (IR -> Comp -> Parametric EQ etc.) but not with the Octaver.
The Boss OC3 has a 'filter' knob so that the octave signal can be applied only to the E and A strings, for example. The Helix has a 'Boctaver' based on the OC2 that DOES NOT HAVE a fliter. (*Essentially the 'filter' on the OC3 and OC5 was a game changer for acoustic guitar players, whereas the OC2 has little value for acoustic players)
How can I set up a Helix stomp so that the Octave effect is ONLY applied to low E and A strings on an acoustic guitar? And how could I output a 'mixed' signal of 6 strings of 'normal' acoustic guitar, plus with the added Octave below on the E and A strings?
Thanks for any help or insight anyone can offer.
  • 11 months later...
